removal of rear seats
TimR26
South Central- West Berks
If they've never been taken out the two bolts for isofix bar will be rusty as they are exposed underneath the car. Soak them in WD40 and leave over night, then you can undo them using a ratchet. When the isofix bar is off there is one torx screw for back seats which again might be rusty.
  Lots of Alfas
A cheap torque wrench will do it, its because they go through the floor and stick out the bottom so are open to the elements, some penetrating oil will do the trick.
  bodied 172 Ph1
I didn't find it a problem, you may need an extension between the torx socket and the ratchet but that's all if I remember correctly! lol..... yeah, man up!!!
  clio172,nimbus 197
my torx bolt was a b**ch to get out not even a garage could bugde it had to hacksaw the head off then weld a nut to get it off but its done now
