172 brackets for wilwoods available?
i want to convert my valver to 172 track, this involves using the 172 hubs, however i dont want to lose my wilwoods, is there brackets vailable? ones that use the standard 172 discs?
our kit wont fit the standard discs, however it will fit a 295mm disc with i can supply at the same time.
the kit allows the fitment of the 4 pot with no need for spacers also.
this is the clearance on a 2118 et37 i believe:
plenty of room.
right how much isit for the brackets? and how much for the brackets and disc's?
I'd like to know also.
Plus, Midge, why are you bothering? The whole Idea of 172 widetrack is surely just for the cheap brake upgrade? The extra track is pretty darn small, and then isnt there a slight front bumper scrubbage?
markone - getting hold off the williams drive shaft's is becomming a right pain in the ass, and the inner cv is pressed on then the ends bent over (so no circlip) you can only change the cv once and when you do you need a bloody mighty press to bent the corners over again. 172 parts are easily available!
