locking car from outside with engine running?
Car  172
is there anyway easy way of locking the car from outside while the engine running? now that the frost has started setting in I'd like to be able to warm the car up for 10 mins before I set off in the morning without having to worry about someone driving off
There are products out there that do this such as "Clifford Intellistart" but they dont seem compatible with the Clios alarm.
I just start the car then go back inside and proceed to eat my breakfast while standing in the window keeping an eye on it :)
best way to do it is start the car. go over to the passenger door, lock with the button inside the car, then lock the passengers side door with the spare key :)
I've noticed on my car I can run out in the morning to warm it up to defrost the windows and the only times I will autolock is when I begin to drive off.
But, being prone to s h * t things happening to me I still tend to not close the door all the way just in case...
it won't lock until over 5mph I believe.
Works. Fact!! Then just unlock by putting the key in the lock. When you open the door the other doors will unlock
car cover for about £10-20, then no frosty windows and no problem with it being nicked.
still will be cold but windows will be clear.
it maybe one of the only features my focus has but having a heated windscreen is so useful! give it 2 mins and its completely clear
Always thought it was bad to idle the car like that. Suppose it doesn't really matter too much on a mass produced engine.
I've had too many cars lock when working on them with the keys in the ignition. Window down is the first thing i do.
why is it?:S
Because it is.
Also will void your insurance if it gets stolen.
2 ltr bottle of luke warm water works every time!
(it dont even need to be hot water, room temp will defrost the windows)
DONT USE HOT WATER THOUGH OR YOU WILL CRACK YOUR WINDOW.
Leaving the car running whilst not in it is an offence known as quitting. Summonsable by the police iirc
I'm sure someone once told me that leaving an engine idling for long periods of time can eventually cause damage to your cat, not sure how much truth there is in that though.
Yeah, but in this instance we are talking minutes to warm up the car. People spend minutes sat in traffic sometimes, with the engine idling.
Even the remote start on the alarms ARE NOT Thatcham-approved so insurance people dont like them.
Several sources have said that leaving an engine idling causes twice or even three times the wear that an engine under load normally experiences (within reason! Bouncing it off the limiter will donald duck it as well!) because the engine is designed to be loaded. The way it was explained to me is that an engine is designed to have resistance applied to it in a certain direction, whereas if it's idling that resistance isn't there and on occasions can even reverse briefly, causing in effect a 'slapping'.
The truth behind this I'm unsure of, but it's one of a couple of reasons that modern cars are now fitted with stop-start.
I was going to use a turbo timer for this (I used to do this on my other car), but couldn't be bothered to look into getting a wiring harness etc.
Timed to run for 6mins, if handbrake is dropped it'll stop as well.
Didin't know it was/could be an offence though.
All sorted now for me. Clio is going to be kept in the garage again from Monday
hmm, still confusing really. but if that's what you've been told then fare enough. seems strange though.
This is the most irritating thing ever! happend to me quite alot i never leave a car running and leave it for the sole reason it will most likely lock itself >.<
Haven't had a break in at my village for coming on 15 years!
Start her up and leave her on the drive way!
