I've noticed on my car I can run out in the morning to warm it up to defrost the windows and the only times I will autolock is when I begin to drive off.
But, being prone to s h * t things happening to me I still tend to not close the door all the way just in case...
best way to do it is start the car. go over to the passenger door, lock with the button inside the car, then lock the passengers side door with the spare key![]()
Its illegal.
it won't lock until over 5mph I believe.
Its illegal.
why is it?:S
car thief could have your clio off the driveway in under 10 seconds if its locked and running. They'll just smash the window, open the door, gone.if you lock it it won't get stolen now will it![]()
Its illegal.
You'll bugger your engine up doing it for long periods of time.
Several sources have said that leaving an engine idling causes twice or even three times the wear that an engine under load normally experiences (within reason! Bouncing it off the limiter will donald duck it as well!) because the engine is designed to be loaded. The way it was explained to me is that an engine is designed to have resistance applied to it in a certain direction, whereas if it's idling that resistance isn't there and on occasions can even reverse briefly, causing in effect a 'slapping'.
The truth behind this I'm unsure of, but it's one of a couple of reasons that modern cars are now fitted with stop-start.
I've had too many cars lock when working on them with the keys in the ignition. Window down is the first thing i do.
