182 from Hungary
Car  Clio 182
Hi ELF friends:cool:
I'm Stephen from Hungary,soory if you don't understood me(i'm a beginner from english:o)
Now:
lowered suspension 40mm Apex
exhaust:unique exhaust with 80mm tail.
stronger engine mounts.
I love foreign Newbies! :)
Hi mate, looks tidy. Any plans or mods for it?
Sounds good my friend.
Are they popular or expensive to own in Hungary?
Aren't popular in Hun.It's a unique car,and many rs are broked,Like my car:dapprove:
The prices:7.000-7.500 gpb
Unfortunately i'v some electric problem.(tempomat,speedo not working,if i starting the engine(in cold),head lights washer...)but the engine is perfect.(34000 miles)....
Ah not so good mate, do you have a good mechanic?
Hi Stephen!
Welcome...
Don't know the answer to the fault code. Sorry!
But i can advice you to do a remap.
Engine will run smoother and rev freer... pick up is also improved.
Your Clio looks immaculate, black shows everything!
Hi Stephen!
Welcome...
Thanks:cool: but the a fault code was t--h(i found it and i reset the comp)
"New" picture.
Im sure those fault codes mean there is an injecter fault and that you should check your oil level manually it may give you a false reading on the computer.
I had they t and the h come up and i just reset it and it didnt return so im assuming its ok now.
But after seeing the codes i check oil manually just incase
You are right,anno 3 weeks ago the oil level was too low..:cool: and i reset now it's ok.
