Removing front swivel hub....
Da
  Less
On a 1.2 Clio (2003), any tips on how to free the hub nut whilst stopping the rotor spinning?
Cheers! :)
stick a wheel on the hub and lower it onto the wheel? loosed to finger tight then jack back up?
or
screw 2 wheel bolts into the hub with a bar going through them you turn the hubnut whilst someone holds the bar stopping the hub rotating
fearless
Stick some wheel nuts in, big bar inbetween wegded against something like the ground, impact gun on the nut! Done.
Da
  Less
Cheers for the advice, got it done in the end. Put the wheel back on and dropped it to the ground, loosened the nut then jacked it back up.
Simple really :)
