has anyone here ever fitted fogs?
  • Thread starter Thread starter jakm15
  • Start date Start date
J
jakm15
has anyone here ever fitted fogs to a mk2 ph1, i have the lights in, i know i need the new stalk but what loom do I need and where does it plug in, i have no idea cant find anything.
any help is appreciated
I bought the full kit from Renault, it came with everything needed - fogs, brackets, stalk and loom.
If the loom isn't already there then you'll struggle to do it OE. Better off hard wiring them as said above.
Loom probably won't be there, mine wasn't, if you look at the fuse box in the side of the dash, there is a space for "fogs" (look at the symbols) if there is no metal in this hole (i.e the fuse won't go in as there is nothing to hold it)
If this is the case, hard wiring is easy enough and can be made to look quite OEM.
A little switch next to the headlight adjustment is best IMO.
what would be needed to hard wire them?
