Removing Rear Wiper
S23
Car  The Cleee-O
Afternoon all. Been trying to remove my rear wiper and the motor so I can fit a smooth blank over the top, but I can't get the arm itself off. I've removed the nut at the top of the wiper arm shaft and tried to give it a good tug but it's not having any of it. Looks to me like the plastic wiper arm has a metal washer on it which has rusted to the shaft. I've tried using WD40 to break it down, but again it's not having any of it. :( Any ideas?
Here's some foto's so that you can see what I'm on about.
Do I have to undo this nut first? If so how, cause there isn't a lot of room to do it :S
Meant to say! I've looked at the guide on here on how to remove it, and have also removed the fascia in the boot itself and the motor as well. :(
ive never took mine of but on previous cars they have been on splines and usally with a bit of a wiggle they came of, but can be tight
sorry im not much help!
Cheers mate, just had another look at it. Doesn't seem like one, gave it a good wiggle and there was no movement. Also it is super flush with the plastic, would a splice sit exactly level with it? Tried to lever it out with a screwdriver just now and didnt even move :(
use a 17M spaner place over the arm and the thread then undo the nut and thew 17m spaner will pull it off its just stuk iv taken mine of before
I had the same problem and eventually prised it off with a screwdriver. Just stuck because of time, rain, etc. When it went back on again I greased it!
halfords do a tool for like £5 iirc but the the guide should do the trick
Tried it again just now, not having any of it. Seems like they've put glue or locktight on the thread so it's not budging anywhere :(.
I used a hacksaw. Worked a treat :)
Did you hack off the bottom by the wiper and then unscrew it beneath the plate?
where did you get the smooth blanking plate from sorry to thread jack
My mate gave me the plate dude, was off of his old car before sold it.
Had the same trouble with mine - absolutely nothing would get it off! Took an angle griner to it in the end, but managed to take a chunk out of my boot handle lol :( Do you mean a completely smooth plate? They look so much better than the standards with grommets in imo.
Cheers for all of your inputs, chrispy.clio I just got annoyed with it in the end so did what you and my mate Chaddy (who used to be on here) said and hacksawed it off. Was so satisfying! :evil: lol Will put the pictures up in my progress thread later :) Thanks all!
