I was under the impression that the gearbox was the majority of the issue.
Does it not run a wider block? The gearbox is much bigger and also the 197 inlet wont fit under the bonnet![]()
Its the head and inlet manifold you want. While the head is off, open up the exhaust ports too as they're tiny for emissions. Mate that to a 182 block and you're laughing.
Ideally you'd want to take advantage of the 197 VVT too but I'm unsure of how you'd get it to work with the Sirius ECU.
puIts the head and inlet manifold you want. While the head is off, open up the exhaust ports too as they're tiny for emissions. Mate that to a 182 block and you're laughing.
It's all about the boost!
This could be a great conversion for someone with a bit of mechanical know how. The twin scroll turbo off the meg would give great low down instant power you could even route your intercooler pipework over the top of the engine the same as a 225, obviously you'd have to lower the boost due to the high compression ratio but I'd still expect 220+ bhp with 220+ lb/ft. you could probably do this conversion for easily less than a grand if you shop wisely. In fact Fred don't you have a F4RT engine kicking around?![]()
ssssshh! you'll unveil my secret plan for the dynacup![]()
pu
Probably wouldnt, but put a cable throttle on and an EC1 ecu and it would be VERY good.
Ive seen it done once or twice...Andy has put F4RT pistons in an F4R block, running the F4RT head and turbo setup etc. Tapped a thread into the head for the F4R cambelt idler...then just bolted the JC5 box on and dropped it in..
pu
and?still amazed at the 230bhp on ITB's and grpN cams "claim", that's 205bhp in english, bloody aussies! LOL
