Inlet Manifold
Car  Clio Dynamique 1.4 16V
I have been looking at making quite a change to the air intake system on my car.
the first problem i have is that on the 1.4 and 1.6 engines the throttle body is at the back of the engine bay. so i was looking at getting a few samco hoses. but that was looking expensive.
Then i came across the inlet manifold on the new megane k4m engine with its side mounted throttle body, more like the sport.
http://cgi.ebay.co.uk/Renault-Megane-2007-ENGINE-1-6-PETROL-GEAR-BOX-/250555495247#ht_3634wt_939
I was just wondering if anyone knew if this inlet manifold would fit my clio as this new engine is also a k4m
Buy mine and make an adaptor for your FBW throttle body.
don't use the twingo RS plenum. It just heats up the intake air too much. (city cruise ~30-40°C above ambient temp)
the "vent hole" isn't an oil breather, it's just a vacuum take-off that goes to the carbon canister. It's unimportant. There's a very small oil hole that you can just put a screw in
yes and the outlet for that is to the left (where the end of your arrow is), which connects to the cannistor.
Hi Manfred,
look this is the difference of these plates (for the old K4Ms) if you have mechanical throttle with an external idle-regulator or if you have electric throttle:
