No deff not the immobiliser as the light goes out after 3 secs.
Tdc?
earth straps?
one near the starter motor and front gearbox iirc
checked inside car yes.all that was really there was the fuse for the radiator iirc.
uch.amm that is behind the fuse box IN the car yes? Yes
amm i dont know i never had to go at it.
what will i check for in there??
Have you checked all Earth's?
Theres 3 in the engine bay, gearbox to chassis, the one near the starter motor and other is on the rear driver side of the bay down there..
Id also check the TDC/Crank shaft sensor, this can stop it firing up, its on the gearbox bellhousing. if its a old sensor(black) replace it with a blue one.
cambelt end is no 4, 3, 2, 1 gearbox end
172/182 engine - doesn't matter
there's a loom earth that bolts to the top of the gearbox (above the driveshaft)
there's a second loom earth that bolts to the main battery earth cable (well goes through the second bolt anyway)
you pressed the fuel cut off button yet?
I have indeed..... Iv even talking it to a mechanic to plug her in and have a look as seen as I couldn't see anything wrong but he's saying he can't get a reading at all
One last question guy's.... Are the Flywheels the exact same on the 172's&182's?
sounds even more like the relay/fuse box wiring, and you're not powering up the ECU
I've had 4clios that have done this now.
2 of them came in running and wouldn't start after an engine change.
All 4 I replaced the engine bay loom and they fired straght up![]()
if youve fitted a new engine it wont be anything to do with the ECU, UCH, keys etc. thats just pissing in the wind!
I put my money on a relay, fuse or earthing
