Broken Top Mount
Car  MK2 172 FF
I was driving home just now and heard a knocking noise coming from the front. On further inspection i found that the rubber of the drivers side top mount had come away just leaving the metal exposed.
Am i ok to drive this until Monday afternoon until i can get the replacement part?
Can i just replace the top part or do i need to replace the baring aswell?
cheers
Mark
drove it to work this morning really steady and was fine, just got to make it until Monday morning until i can get a replacement part.
You can get the rubber mount and the metal top bearing seperately, bought both lots yesterday!
where did you get them from bearne? how much did you pay? part numbers?
Hi,
got them from a local parts place. Gsf claimed they don't do them but euro car parts have both items cheap.
Hope it helps,
Daniel
cheers.
how would you tell if the top bearing is fooked? is it just seeing if there is any play in them?
Hi,
not too sure really, mine on the car seemed very loose and rough but think that's normal. I think they collapse or fall out of shape on top of the strut when they go (although I'm no expert!)
got two new top mounts with bearings for £40.
Renault wanted £18.15+VAT. not that much more but better in my pocket lol
Part Number - 770426450
i need new top mounts i think, i get this horrid knocking when turning and then also when i hit a bump, just one solid *bang* been told it could be the top strusts knockin on the chassis, was it any reno dealer you got these from?
yeah it was. I actually bought the full kit.
I got the top mount and nut, the bottom mount and baring. So all of number 8 in the pic below. I also got new strut to hub bolts and nuts. it came to a total of £106 and a few pence, so not the cheapest of things to do but that was for both sides
i need that too i guess, the knockin is doin my head in lol plus on full lock, when i look under the bonnet at the strut mounts, they seem to be bent :S lol and they move alot
the knocking could be the brackets on the steering rack, that was another suggestion from someone i read in another thread.
Can you post a pic of the mount?
