on my 05 1.4 dynamique i've got a couple of minor problems/annoyances with it which have developed over the last couple of months.
1: When pulling away it feels as if the power (all 98bhp of it :rasp
is restricted, then after a couple of seconds it will take off again. Thought this would have gone away when the ignition coil went last month. Replaced all 4 of the pencil coils but no change. This is sometimes coupled with it feeling/sounding like it is going to stall just after it starts up. The revs drop really low then back up to normal idle speed again.
2: A tricky one to describe. When sitting at idle the car will sort of...judder every few seconds, not much but enough to feel it through the seat...and it wobbles the gear lever if you watch it. It gets annoying after a while.
I know most of you are 172/82/97 owners but maybe some of you have had a similar problem to those described and know a fix?
Thanks.
Thanks.
