Adey.
		im no keyboard warrior, tho when a mate of mine seemingly gets ripped off for 2100 sheets im guna have something to say no? any one want to give me a shed load of cash so i can find out what to do off a forum?
a clio 172/182 F4R on ITB's with cams (428's in this case) timed up and mapped properly should do over 200bhp and 170lbs/ft as a MINIMUM, if it doesn't there is a problem somewhere!
why didn't you just tap into the OE loom "piggy backing" your way in and leave the OE ecu to run the dash? seems bizare to remove the oe system!
Fred, we have autodata, in your expereince are the manuals a better bet?
do you need the renault workshop manual on how to check the timing?
Danny,
Now this is why forums are the best resource out there! People wanting to help
Nick will be dropping the car to us Tuesday evening, so if your up for popping over and casting your eye over it, more than happy to accomodate with tea, biscuits and plenty of good humour
Cheers,
Matt
Another area of interest for me personally on this particualr engine is the fuel system, theres no return, and the fuel pump relay is powered along with the coilpack so its not ECU modulated... I assume that it is self modulating in tank? I would of thought it hard to accurately maintain rail pressure over 3 meters of fuel hose...
However, it could be a useful pump for some motorsport applications....
and what would happen if one of us "well known" specialists let a car leave that was below par?
Nick was too tight to go to a Renault specialist!!! He did not want to spend the money!! Lesson lernt me thinks. Good on Mtech for putting in the effort to sort this out!:approve:
Yep seems you were happy when you picked it up and then without giving them a chance to sort it your on here slating them.
Give them a chance dude i'm sure they'll sort it as they sound and look like a professional outfit.
