Clanging from the bottom end - phase2 172...oops
Car  RB 182
After doing a sprint day at Curborough about half way round my first timed lap the engine gave way. It still drives but makes a clanging noise when revved.
I trailered it back home and will need it inspecting but has anyone know of what it's likely to be, and what can I do to increase the robustness of the bottom end?
any help appreciated
Spun a bearing, A knocking noise yeah?
Has it been run Low on oil
not since I've had it although when I bought it I had to change the sump as it had a crack in it..hmm a story is unfolding..
so does this mean just new bearings do you think..?
Its hard to say there are so many possiblilities You could end up needing a new crank if its bad
I guess its a case of opening it up and assessing the damage.. do many people bother getting things balanced lightened or hardened..? as now would be a good time if its worth while
Just squeeze a meg 225 lump in there :) for the price it could cost for a full gasket set and any machining work thats required, an engine swap might be the cheaper option.
