I think Bazzon meant standard (i.e. without the grooves) Brembo HC instead of the Brembo Max (which is also HC).
I've got the Max, and personally, on a day-to-day basis I find them really annoying - they make a rumbling noise as the pads pass over them. I like the look of the grooves, but I'd suggest the normal non-grooved items.
The first thing I did was have Goodridge braided lines and Castrol Super Response brake fluid fitted/added.
And Pagid Blue front pads fitted with the Brembo Max. I've yet to try the pads/disc combo. on track but I'm expecting good things from the pads. They're great for normal use - squeal a bit sometimes, but not too bad. I'm hoping they'll stand up to the occasional track day, but probably overkill for the tiny number of track days I'll get to do. Most seem happy with the Ferodo DS 2500.
I don't think the Brembo HC are better than standard discs - just cheaper.
I think standard pads are fine for road use only, but not for hard track use.
