he means what headunit is it. the 182 had 2 options, tuner list or update list. it says which 1 it is on the front.
each 1 requires different equipment to get an aux in hence y he needs to know which 1 you have.
rofl.the chances.ok another way to check what method of aux in you can have,turn on the radio,press and hold the settings button and scroll through the menu options,if you have an option to turn on aux in then its the cheaper version,if not the more expensive type it is
EDIT: did it not say in the bottom right hand corner next to number 6 tuner or update?
