Got STANCE? (Pic Heavy)
No, me neither, but I though I'd give it a try! ;)
The day started out like this.
Wheels completely lost in the front arches, not quite positive camber, but not far off.
I disliked this. Alot!
So, I posted up a wanted thread for some 25mm spacers, and yesterday they arrived courtesy of Alex_C, Thanks again fella! :)
I carefully fitted them, as i've heard bad things about Delta Mics Bolts, and was left with this:
Yeah, not bad... but PH2 Dynamique wheels were fast becoming boring, and I needed a change.
So, following on from my thread "16" SuperT's" http://www.cliosport.net/forum/showthread.php?t=509795 i fitted these, along with the spacers...
I then had big scary visions of the arch slicing the tyre open when cornering, so then proceeded to fit a pair of Camber bolts.
Set to Maximum negative :cool: the top of the wheels went underneath the arch - a little safer now. And it does look kinda cool!
Did the same to the other side, and fitted the rear wheels, and took it for a drive :)
Had to raise the front quite a bit too :dead:, and remove the arch linings... still scrubs FFS!
No, i couldn't be bothered to wash it, and yes it needs tyre gel...
But it took forever to make the thing driveable!
Think i'm going to invest in RS Arches next...
We'll see!
Thanks for reading :)
Comments & Critique welcome...
i get what everyone is saying - i'm still not decided on it all myself.
And yeah, the rear needs to be seen to. All in good time!
Stevie G i got them from ebay - advertised for a suzuki vitara :)
Completely agree Steve. But i'm 18, and i love my car to be horribley inconvenient at every speedbump etc ;)
i wasn't going for DUB stance BTW, otherwise yes, i've done it completely wrong!
was going for more "Cup Racer Stance"?! :S lol
i think mine should be around -3... although i've no idea.
no idea why they only say 1.75?
How many degrees is that Ph-reebone?
I do like those Image wheels TBH
/jealous :o
Found the shims on venom, but they dont do them for clios :S
Only twingo, laguna, espace, and scenic..strange.
Quite cheap though!
They are for the sport model though.
They will be different to fit behind drums and disks you think?
