172 throttle pedal part number ???
Following on from this thread.
http://www.cliosport.net/forum/showthread.php?t=511524
I went to my local dealer.
Why are Renault parts departments in Aberdeen so useless ??
I called them this morning to see if they could give me a price for a ph2 172 throttle pedal and see if they had one in stock.
they came back with £52, so I say ok hold it and I made my way in to get it to be giving a plastic pedal on the assembly, which needless to say is the wrong one and I told them I was after one with a medal pedal.
Lol
Then they said that the pedals on all 172's are the same which is s**t as there's fbw and throttle cable ones which I had to explain so after much time i'm no further forward.
Can anyone help ?
Does anyone know how much they are and what the part number is ?
I got given this print out if it helps
Is the pedal assembly circled (number 2) the pedal assembly i need to order ?
As they didn't know which is worrying even when I gave him all the numbers written on my throttle pedal housing.
maynard
  ph2 172 track car
as up to date as of 10 minutes ago ;)
it's the current renault part number that they're using. the number you've got is probably just a superceeded number. it happens quite a lot with renault.
Ok cheers mate.
Where did you get that number from
