f**king hell !!!!
Its a bit of a s**tter whats happened mate but i guess the good thing is things are happening to get the car back on the road althought you'll be a bit lighter £££'s wise
If it was a material defect in the valve itself, couldn't you keep all the evidence and try and claim to Renault for defective materials etc if your car had full Renault service history ?
Or would they just f**k you off with the valve has seen intense heat and cooling down over its lifetime and has weakened it or some b****cks like that ?
I guess there alway a bit of money to be made from what you have left part wise from your old engine though
Well I am aware of what you are saying, and the mentioned happened 400km after the cambelt and aux belt sets service which had been done by Renault service. My friend that works there told me that before the service cambelt hadn't been timed properly, and had a slight misfire though which disappeared after the service. The previous owner must have gone to a local garage which had no proper tools. I also heard that he had had problems with cambelt slipping which resulted in bending few valves. He might have changed the ones that were visually damaged and left some old ones that looked ok and should have been binned.
I am afraid that there are no such things as claims for defective materials in Montenegro
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here u have to be hit by a car to get some compensation.
Not many parts which I can sell from my old engine. Cams are ok, and no other parts that I can use. I can make a really nice table from my engine block though
But the most important thing is not to give up. It is not an ordinary car and I think it should be kept and enjoyed. My car is the only clio sport 172 in the whole country, which is a bit difficult when finding used parts. But we have a great Renault service so I can always order new ones.
I have waited for 5 months to find an used 172 engine, finally I got it and now I am having it rebuilt with new parts: big end rod bearings, piston rings, gasket and sealer set, new valve guides, valves, sparkplugs and clutch kit. All done by Renault and I get a full warranty for engine.
