Is there any way I can run a hose from say, my kitchen tap? Unfortunately I don't have a tap/hose outside and it makes cleaning my car an absolute nightmare. Having to constantly fetch buckets of water, most of which ends up on my feet!
fit an outside tap, get a kit from b&q for about £20....
Ah didn't know you could get a hose connector for a normal tap. I'll have to get one and try it out!
It's not an option to fit an outside tap unfortunately - listed building
Donny, depending the grade of listing, it is quite possible this type of alteration would not be allowed.
Above BBC link said:If a building is on the list, any building work will require 'listed building consent', according to the Planning Act 1990. This is obtained through the local planning authority. Even minor works, such as painting or simple repair work in some circumstances, falls under the scope of this act.
The penalty for ignoring this act is up to a 12-month prison sentence or a fine to an unlimited amount, or both. Then you can be expected to carry out, at your own expense, further works to the listed building to remedy the impact of the unauthorised works.
Yep. Have a look at this, gives a basic overview of listed buildings renovations and improvements regualtions http://www.bbc.co.uk/homes/property/moneyandlegal_renovatingrulesandregs.shtml
ONR - optimum no rinse. http://www.elitecarcare.co.uk/product_info.php?products_id=596&osCsid=28nnao
Watering can flol?
All the sheet dirt etc from gardening pouring onto your paint? :dapprove:
