Does anyone know what model these Enkei wheels are?
Car  Clio 182
Refurbed in red but does anyone know the original model so I can find the offset & width of them.
All i know is they are lightweight enkei wheels with 195/45/15 tyres on
Not very wide! Here are the measurements
5Jx15 (basic size)
4x100 pcd (the bolt holes)
54.1 centre bore (the hole in the middle)
45ET offset (how close to teh outer edge of the wheel arch they are).
Probably a tad wider than motorbike wheels!
And center bore is too small for clios? and offset will need spacers if you dont' want them sitting right inside arches?
i think your gonna need spacers/ adaptors. can't remember 100% but think the outside dia on the hub is 60mm so the centre bore won't sit over it.
someone could probably confirm this?
Then how comes this worked with no modifications?
Clio Dynamique alloy on Marks Ignis?
Because... the centre bore is bigger on the Clio wheels, so you can use spigot rings to downsize the centre bore if you want them to fit properly, but you can't downsize the centre bore without adapters.....
I understand, thanks.
Hopefully I can get my £50 deposit back :(
You could probably say goodbye to that £50, should've did more research before u put the deposit down! Ahhh well not a massive loss if u don't get it back!
