F.A.O Mechanics or PH1 geeks
Car  Stagecoach Ticket
Plugged the ph1 in today after being 2 lazy to do it over the weekend. Pinged back "circuit knock Sensor" this is the sensor on the bottom end of the block yeah? with the brown casing. Is it just a case of pop off pop on job done?
J
Thanks mate thought so but always best to check will change it in the morning might get some mpg/performance back then!
I think (could definitely be wrong) that the knock sensors just keeps the car alive? i.e if it's faulty the car is prone to stalling/not starting? Or is that the crank sensor? or are they the same thing? LOL!?!?
Thats crank sensor mate :)
Crank sensor notes the rotation of the bottom end, it bolts to the block just above the box, the knock sensor is just by the oil filter
Ahhhh, yeshhh, I remember when I took out the wrong thing, LOL!
I learn something everyday, cheers Russ.
Now ITB my car!
You need to come see mine at some point lol
what are the symptons of a faulty knock sensor?
I didnt realise mine was faulty untill I checked the fault codes tbh, though after fitting a new one it did seem to pick up better
s**t MPG
bad performance
limp mode like performance
exhaust will pop and bang on idle
proberly more but there common ones
As russ sais thats the crank sensor mate
Cheers russ thought it was the one but was just checking before i orderd up and changed it
£27 all in seem pretty good for the part? thats with discounts etc
Had to come from local reno in the end as unipart dnt stock em off the shelf and there normally massivly over priced due to being in a posh little village did full trade and futher discount apparently.
Thanks for quick reply mate
Are these common things to fail?
Would these cause the heavy puffs from the exhaust every couple of seconds?
No worries fella :)
With issues like that mate, just get it onto a diagnostics machine - you could end up throwing money away
No worries fella :)
LAAAAAD, don't say that....
Is clip the only machine that'll do?
Would rstuner be a good start?
as russ sais get it plugged in mate
But it could well be if your having puffs and pops from the exhaust
But could also be lam sensor,cat,air leaks,blowing exhaust + many more mate
s**t MPG
bad performance
Mine summed up then lol,
Although no fault codes come up :s
