whats the best spacers to get ?
Car  CLIO PH1 172
so i will be putting atleast 25mm spacers on each wheel but have heard some scary stories about bolts snapping ect...
what ones are good to go for that dont cost £££'s ?
im after some names/makes and places to buy them if your feeling really helpfull :D
adam
25mm spacers? What the hell for? If you really want to do this, you'll need much longer wheel bolts and also remember that the stresses on the hub etc will increase. Might not be significant but you'll probably need a suspension geometry check afterwards. I reckon 10mm is as much as you want to go.
why would i need longer wheel bolts if i get hubcentric ones that bolt on ?
also would it really give that much more stress on the hubs ect?
I have to be honest that with a clio, I couldn't say, but I know from experience on other cars, wide spacers can add extra stress onto the hubs and throw the geometry out. If you have bolt on spacers you shouldn't need extra length bolts.
your correcet it will put more stress on the hubs ect but not that bad thers hunderds of clios running spacers inc some of the race cars !
I've got FK Hubcentric spacers, which are 20mm each side. They bolt to the hub first, then your wheels bolt to the spacers using the original bolts
I got them from FK direct, even with postage from Germany they were much cheaper. I've had no problems :)
Have a set of KEI spacers to go on my C4.
They are the bolt to the hub type, they also convert it to nuts rather than bolts.
We're abouts did you get them from wozzaa ?? Thanks
Any dealer who has Kei stuff should be able to sell them. Quite cheap as well compared to most spacers. Come in 15mm and 25mm fittings I believe. Can normally get a set of 4 for similar price to a pair of H&R's. I actually got mine 2nd hand from someone who got rid of his car and returned it back to standard.
what are the bolts like on the fk's?? had any probs?
Nope no problems whatsoever. They're the system B ones, so came supplied with bolts to bolt to hub. Have been excellent, high quality.
Also got a pair of FK system a hubcentrics, got the extended bolts from europerformance. been excellent as well.
