removing "renault sport" badge,
Car  recaro'd 172 rep
been thinking about taking the rear badge off.
whats your oppinion's and how do i do it without leaving a mark? thnks
Hair dryer and fishing wire to remove, then AG tar remover for the marks left over. Wax area after.
I just removed my badges but it left the glue behind and now it is a mo fo to get it off, tar remover isnt budging it.
I just pulled mine off but it ended up in bits.
Probably best to get some heat on it with a hairdryer as it'll heat the glue up and make it easier to remove. The shadow that gets left behind can be polished/waxed away.
Two minute job.
Hairdryer and a credit card. Then use some B&T or SRP on it afterwards to remove the residue.
its off but its 2 cold outside 2 remove the glue. ill attack it tomorrow and get the glue off
I used boiler hot water and a card, worked find and got rin of most of the glue!
whatd be the best thing to do to remove the clio badge on the opposite side?
normally just pops off with a little patience, a screwdriver with a thin cotton cloth, like a pillow case type material on the end will be enough to wedge underneath and prise it off. will leave two holes though, best way to fill them is put a plate or some fibreglass mesh on the inside of the hole and use filler on the outside to build the layers up, smooth it off and get it sprayed. a lot of work for one badge though
