Eibach sportlines and Koni adjustable dampers on the way!
if I want to install Koni damper on Eibach Sportline spring, is it needed to remove or cut some of the bumps top rubber?
why I find only find 10mm travel distance when install Eibach Sportline onto the standard damper (bumps top damaged after driving few times)?
