Hopefully someone here might be able to shed some light on this one for me...
Just moved into a new build block of flats that has been wired up for Sky and a communal dish on the roof.
We have sigend up with Sky for Sky+, broadband and the phone line.
The guy came round yesterday to "install" the Sky+HD box which basically consisted of plugging it in the wall
Here are the questions:
Now the box has been installed, how long does it normally take before having the bits I need for the broadband and phone line to be set up?
I still can't watch Sky . Even the guy installing it couldn't work it out. Input 1 has 0 signal/quality and is "not locked" yet input 2 is fine (signal/quality at about 75%) and locked is "OK" (I've tried swapping the cables around but gives the same result, the engineer also tried a different Sky box with the same result)
Now I don't really know what any of that means but when selecting a channel it simply says no signal with an error number 25.
The guy didn't know what to do so he left us with the box plugged in etc. We have contacted the developers of the block of flats and they are going to send the electrician round (not sure what he will do?!?)
I've also seen some info on the net regards "resetting the LMB", again not sure what this is or even if I should go ahead as it's a communal dish and I know there are others in the block that can recieve Sky.
