HELP HELP HELP!!!
Car  1.2 clio
driving home from work the engine management light came on it started to feel lumpy to drive didnt hav far to go so i carried on.. got home put in a fault code reader and it came up with... PO141 generic O2 Sensor Heater Circuit Malfunction (Bank 1 sensor 2)
also engine was warm and the needle went really high :/ the fan didnt kick in at all please help !!
MAF problably. Disconnect the MAF and then start the car and do a run to see if it continues in "Limp Mode". If not, replace that part.
where is that part??... im guessing its a lambda sensor but what one i have 2.. one b4 the cat and one after ??
In the inlet air tube, after the airbox.
I can't help you further, I always had dCis, never had a Clio Sport.
EDIT: Normally it's a small part inserted on the air tube, that looks squared and it's done by VDO or Continental/VDO. It has 1 cable connected to them. At least in the dCis is like that.
