Gear linkage gaitor perished...
The picture its just a rubber boot to protect it from dirt,
But if there is a worn bush then yes that could cause a bit of sticky gear change if its well worn
Ah ok. It's just the bit that's pictured that's Knackered so if its not that important then I won't bother. Lol
Sent from my Desire HD using Tapatalk
well its not the most important thing but there is usually grease in there and if its a small hole should be fine but if its split open and if left overtime then could get filled with dirt and cause stiff gear linkage,
i would just use some glue or sealant to close the hole and its fixed :)
ofc make sure theres some grease in there too
Cheers. It's completely had it so ill get one ordered
