Hey guys! Out of boredom I decided to remove the rear wiper but now I am left with the stipud screw thread which I'm not too sure how to remove :S
Its pictured below..
Quick question, the plastic surround... How does it come off? Does it just pop off? I tried using a screwdriver to lift a corner of it but realised it wasnt come off too easily and was afraid of breaking it!
The plastic blanking plate thing you pop off, use a flat blade or something, then underneath there's a big nut (22mm I think) on the outside, undo that (well I did anyway) Then on the inside there's two bolts holding the motor to the inside bootlid, remove them and you can take the whole thing out
Edit: Oh and use something like AG Bumper care on the plastic, worked wonders for me!
The plastic plate is on two big push bolts, get it from one side and pull and then the other side it will need a good sharp pull.
The inner plastic will just pop off once the torx bit inside the handle has been removed.
You have to clamp the screw in place and then remove the bolt.
I used some plyers and lodged it behind the bolt. Or try clamping it from behind the entire unit. its a pain to get behind but gives you more room to twist the bolt off.
Have you removed the big bolt under the outside cover? this could be holding it in place not letting it move, which made the bolts just round off inside?
