Project 172 take 2!
Martin_172
progress is slow at the moment due to paying for my holiday, the dci needing a clutch and cambelt and generally working flat out having no time for the car! done a few wee bits tho...
engine cover finished...
got an RS Tuner and put the 98 ron map on it with raised limiter, then went in search of that limiter in 5th gear, i knew ph1's had a longer 5th gear didnt think it was that much longer, topped out 1,000rpm from the limiter lol...
rear reg plate light was faded and looking past it, replaced that along with new fresh, clean reg plates
front plate...
shiney engine cover bolts...
6000k HID's went on (cheers http://www.hids-direct.co.uk/)
  RS6+ & 40d MSport X5
LOL @ posting pics of doing nearly 150 then posting you're reg.
Mentalist.
Tis nice tho :p
Martin_172
Worth getting an RS tuner then? Does it really give a bit more power lower down the revs?
i didnt notice a massive gain however ph1's have a much better mid range than ph2 cars anyway so id imagine on a ph2 it would make a decent difference.
the raised limiter makes it worth while for me, and once the pops, bangs and flames map is released it will be awesome!
Mentalist.
Tis nice tho :p
it was on the autobahn buddy
Martin_172
few updates nothing special, gave it a wash, changed the sparkplugs, going to do oil and filter on it this week at some point and got Bilstein B14 coilovers lined up for it...
Martin_172
never! i like silver :) they are getting done next month due to having to weld a blob of weld to the locking nuts and hammer a socket over the blob to remove lol some burn marks on the wheels (was planning on doing them anyway!)
on the look out for a 2nd set i may do black though!
Martin_172
this has been quiet for the last few months just been collecting parts.
stripped the inlet manifold off it, re painted it silver along with the fuel rail guaurd and the arm on top of the throttle body, ordered and fitted a brand new ph1 172 Airbox as i had lost the clips for mine and you cant get them sepporate!
waiting on a new battery and new 90 degree inlet hose and its ready to get fired up!
also had to change the alternator for a brend new genuine renault one and a genuine renault AUX belt kit, that was fun... NOT!!!
Uploaded with ImageShack.us
all the black metal bits around the battery tray are off and rubbed down ready to get re painted, got Renault Type D coolant for it, want to order a new coolant resovoir tank for it to tidy that up a bit, wont stop untill its 100% mint as it left the factory, this could get expensive!
