182 exhaust manifold and cat fitting to 172
Car  corsa D / 172 clio
hi
does anybody know how long the cat is supposed to be when fitting this set up to a 172?
is it the same over all size (manifold and cat) as the 172 set up or would it need
changeing?
i know the ends are different and a flange would need welding on.
im sure someone has fitted this to their 172 so any info would be much appreciated
thanks
(if by any chance someone has a knackerd 172 cat with a decent end pipe and flange
on it then let me know!)
You would need something made to fit, or go onto ktecs website and I think they do a link pipe, I think a couple of people have cut and shut a 182 cat to fit in the gap, don't quote me though.
hi guys
thanks for your replies but i think you are missing my point!
i don't want to fit a decat pipe i want to convert a 182 200 cell cat to fit the 172 exhaust system using a 182 4-2-1 manifold up front.
OK lets ask this a different way
can anybody tell me if a ph2 172 cat is the same size in length as a 182 cat from flange to clamp end (will be flange to flange on the 172 cat)
thanks
hi guys
thanks
no, as said several times already, you'll need to have something made. It's not very hard though, if you can weld
Here you go.
I bought a 182 sports cat from here...i had a spare 172 manifold with a fake cat.
I had it cutted and used the flange with the 182 cat:
