Renault 5 GT Turbo, F7P Turbo Powered Tungsten Track Car.
Car  Mk1 Focus RS
Have been on here for a couple of months now, So I thought I might get my project copied over as there seems to be some quite knowledgeable people over here the should be able to help me out along the way. ;)
Started on. 17/03/2011 but trying to shorten it down a bit. If people could hold out replying until I have it all copied over
Bought this back in July 2010 with the Idea off just using It for the shell. It had a full re spray a couple of years back and both sills replaced recently, So was a good base to start on.
Then I was away in Canada for a month so nothing happened to it for a while.
While I was in Canada I decided I was going to sell my other Black Renault 5 GT Turbo and focus more on this one.
So 6 months later I finally sold it last week.
With it's new owner.
I hadn't really touched the grey since I bought it and it just sat on my drive looking like this for months.
My plans where to fit a 180-200bhp Renault 5 GT Turbo engine that I had and turn into a reliable track car. That then went out of the window when I was offered a complete F7P Turbo converted Renault 5 GT Turbo. It had only done about 1200 miles since the re build and had receipts adding up too thousands, so I bought it ! :)
One on the way back from picking it up, notice the extra ramps I had to put on under the car as it was so low to getting on the truck.
The engine
Over the last 6 months I have been collecting some parts though, also cleaning up some others bits that I already had.
Safety Devices 6 point roll cage
Sabelt 6 point harness and seat
Willwood 4 pots
Carbon fibre bonnet
15" Oz super turismo wheels
Poly bushed sub frame with new ball joints and track rod ends.
New wish bones
Starting work on the good grey one
Day one - Interior out
Day two - Engine bay
Day three - Got In the garage now and I managed to remove most of the seam sealer.
Day four - Carried on with the interior, Dash, loom and heater out.
Some help from Daisy.
So that's it so far, I've missed loads of bit's out like the 4 hours I spent scraping sound deading off one night, other panels, side skirts but all of those pictures are on my camera, as you can see these one are just the s**t ones of my iPhone.
I have got so many plans for the car In the future, but I'm holding back on alot as I really want it ready for the RTOC track day at Mallory Park in June
Sorry about the poor grammer and s**t spelling, but It's late and I've had enough :p, will do my best to keep this updated. enjoy :) Lewis
Few more pictures.
Lovely steering wheel Isnt it :p
I bought some OE replica dails as it's really common for the faces to fade, especially after 20 years as you can see. Also a new clear plastic front as mine had a crack in it.
Today though I had my new clay bar and wheel wax turn up. So spent some of the afternoon claying my front bumper. Got a bit carried away and wanted to clay more stuff, so moved onto my wheel's, I only got one done as I've now have a blister on my thumb. :thumbdown:
Few more updates and pictures of my phone, was working like crazy all over the weekend until 1am most nights. There is so much work to be done and everything seems to take twice and long as planned. Still good fun though. :)
Bought a filler neck of a Renault 5 Campus to replace the second fuel tank found on the GT Turbo.
I borrowed a welder to patch up a few bits, Lovely gas less MIG. Not ! hardest thing I have ever used. That's why it looks like this :p
Carried on though and done a patch in the engine bay after using Kurust on it.
Also lost the last of the seat brackets.
Finally moved onto removing more of the seam sealer.
This stuff makes such a mess and get's everywhere.
And that was my weekend, again missed so much out but I will try and get the camera pictures up soon.
Done some more welding with the worlds worst welder I borrowed.
The weldings not the best, But I will be grinding most of it back.
Then moved onto removing more of the seam sealer.
Spent most off friday night In the garage cleaning of the glue left from the head lining,
Cut away some of the bottom of the front bumper to try and save some weight from it as its solid,
And then spent the afternoon wet n' drying the front end down ready for painting.
Just can't wait to start building it up now.
Got the most of the front end in paint now. It was going to go to the body shop to have the inside and engine bay painted gloss black, but time is tight before Mallory Park so I decieded to do it myself. I was given 6 can's of Ford matt black for free so thought why not, It was only meant to be a quick job to protect it from surface rust, but you can't seem to ever do a quick job on this car. :rolleyes:
The yellow stuff is filler primer, then hi build primer on top.
1200 grit wet n' dry
Cleaned down the surface with some panel wipe
Matt blacking, the bits little bit you see are seam sealer that flicked up as I took the pictures later in the day.
As I'm running bonnet pins on the carbon bonnet I cut away the catch.
Removing more seam sealer.
Wire wheel disc after about 6 hours use :p
Mates turned up so got them to sanding and scraping on evan more seam sealer.
I got bored at this point, So I put my 15" OZ wheels and my mates Clio 182, Coilovers want winding down now though.
Had 6 cans of 3M under seal turn up today, The 6 should do the whole of the underside of the car and inner wings.
Painted most of the front end now and trail fitted the front wing.
Then gave the bonnet a clay, polish and cleaned the catches.
Started on the rear end at the weekend as the front is done for now.
Had some pleasant surprises when I took the rear bumper and arches off though :crap:
Wasn't happy at the weekend and really wanted to through the towel in with the whole project, it's just turning into such a big job ! Wished I had just bought a newer car something like clio 182.
So after my little sulk, I started up the other car with the F7P Turbo engine still in, that put a massive smile back on my face so I'm back on track. :)
Next day I got the car back out and winched up the front end ready to do the underside.
And that's how it still stands. :)
Not really done a lot over the last couple of days, as I felt I've been working on the car every day and night since I started on it. So went out clubbing friday night and turned up to the RTOC meet down Southend seafront by mistake last night :p
I did get my willwood disc's painted though, as they have been sitting around the attracted some surface rust, and rusty disc's do look **** !
Rubbed them down lightly with the angle grinder wire wheel, then gave them a light coat of very high temp paint (the pads will just wear off the paint on the face)
That's it so far, again there is still so much to be done but looking back at the first pictures I realize how much I have already done.
Sorry about the massive amount of pictures, and hope you don't mind me bringing my non Clio over here to CS
Will do my best to keep this updated, enjoy :sleepy:
Lewis
oh my days..... thats it, im getting a 5 at the end of the month :-P
looking forward to the updates, shame about the rear end but very fixable i think even the mint ones have inner/outer arch and sill issues nowerdays!!!
Thanks for all the comments, Yeah they are all nearly 20 years old now ! so all have rust in some places.
Stared the job today I have been putting off for the last week, wire wheeling the underside of the car ready for underseal !
I had to go and buy a new grinder first as I killed the last one.
http://i910.photobucket.com/albums/ac305/LewisCunningham_badass/Grey%20Renault%205%20GT%20Turbo/DSC03708.jpg[/IMG
Holding the grinder in the air for any length of time kills your arms, so kept stopping and done some other jobs
Stripped down the rear beam
[ATTACH=full]786658[/ATTACH]
[ATTACH=full]786659[/ATTACH]
Cleaned up the rear disc's ready for painting like the front ones, They look s**t and eat through pad with the grooves In, but I might as well get some use from them before getting new ones.
Also took the bottom of the boot lid off as I wanted to change the badges over to an original one I had on my other car, the cars are different shades so I can't just clip the other strip back in.
[ATTACH=full]786660[/ATTACH]
It does have some laquar peal but I'm not sure what I'm going to do with it yet, as I don't really want to paint it.
[ATTACH=full]786661[/ATTACH]
I made a right mess taking the old badge of as it was all bonded on. It's going to be to visible with the new smaller badge fitted, so I't really needs re-painting. The problem Is, the paint is a non OE paint and a mix of a few different colors so will be really hard to match. I think I'm just going to do it gloss black for now or get it carbon wraped to kinda match the dark black bonnet. :/
Thanks for the comments, yeah I loved that black 5 just needed the money for this.
Stick with your Clio's, less hassle ! :rasp:
I completely agree on this being that I've worked on this and it's one thing after another lol but its gonna be a beast when it's done ;) although still want one though haha!
Fair play that's a big project you've got on your hands. Stick it out don't cut corners rid if of metalworm and the end result will no doubt make up for all the hours of graft.
Thanks,
Slowly getting there with cleaning the underside down, Done about half of it now.
Cleaned up the the rear beam a bit, looks a lot better than I thought, considering how rusty it was.
Cleaning up the rear arch,
Then Cut away some more unneeded weight, also the rear compensator bracket andd spare wheels cage hangers.
That's it for yesterday.
As I wont be running a heater, I filled in the hole's for the fan and heater matrix will some thin aluminum sheet.
I also made some new mounts for the bonnet pins, Again out off some aluminum strip.
Mk 1 vs Mk 2
Finished, Cut away unwanted thread as well.
Right, not done a lot over last month really, as I figured I was never going to make Mallory Park in June and I didn't want it to be a "that al do" project, to get it finished.
On the plus side, after weeks of research, phone calls and haggling I got a myself a new welder.
If you know about welding you will know how good Lincoln Electric welders are! I went for the 191c model with the new Al bee gas.
Also bought some campus rear window seals, as a mate Is looking into getting templates made up for 4mm Lexan poly carb windows. Plastics for performance want silly money for there window kit, so im just going to make my own.
Will get some pictures up tomorrow.
To start with I've done away with my Photobucket account and gone over to Flickr, as it so slow and always sticks my photo's in different albums. I'm hoping I doesn't mess my pictures around much from the thread though.
Done some work on the boot lid at the weekend, mainly weight saving and just cleaning it up.
Firstly removed the glass as I'm going to use perspex windows and the glass had a big scratch on it.
A lot easier than I thought.
I had all ready taken out the wiper motor and arm then worked out what I was going to cut off.
Cut away the cables for the motor and heated screen.
Forgot to get a finished picture.
Also bought a couple of meters of CDS as I'm going to ad a few bars onto my roll cage.
So Lewis, what's happening with the 5? any more updates
Done a few bit's over the past week, but as you may have guessed I was away at Mallory on saturday and horse show sunday, so not got anything done all weekend one the Renault.
Pretty much finished seam welding the spare sum frame, Welding looks s**t but I just been practicing with the new welder.
Just need to get it powder coated now when I send the VW Beetle floor pan off.
Decided I'm going to paint the inside of the boot matt black like I'm doing the rest of the inside so it doesn't look to out of place.
So started some of the prep work.
Don't really have a target, just removing all the unnecessary stuff.
Painted the bonnet hinges.
Also finished the steering rack tonight as I got the new gaiters this afternoon.
Selling up,
Just lost interest and patience with the project, needs a lot more money and time spent on the car and realistically isn't going to be finished for another year yet. Can't wait that long so I'm looking at getting a myself Clio 197 for the time being, maybe come back to 5's in a few years time.
All parts will be going up for sale, If you see anything in this thread you like PM me.
Lewis
^^^ He's selling up mate, shame as i love Renault 5 restoration projects.
Right......
What seems to be months without working out on the car has only been weeks but I have to say I've missed it! After quite a few debates and a lot of thinking I'm going to carry on the Renault project! I've spent all this weekend away with Cliosport.net and as much as I would like a nice new modern reliable car, the Clio 197 is just too boring for me!
Bit gutted that I did sell a few parts, but they all can be easily replaced. Glad I never let the engine go but then the advert was pretty bad.
Spent this evening putting a spare interior loom in and got the engine turning over. I'm going to do things a bit different to what I originally planned, so watch this space.
Lewis.
