Fuel pump not priming on ignition
Car  Itb'd 182
My fuel pump isnt priming on ignition , ive ran a direct feed to the pump and wired in two different plug ends so ive ruled out pump faults and plug faults , which relay is for the fuel pump ?
there are 3 small black relays in the fusebox next to the battery. Pull them out and give them a sharp tap then replace them. likely it will work then
just went out to give it a try and its still not priming , the light under the fuel warning light is on the one that looks like a heartbeat , no power at the coil or the fuel pump , ive got no idea what else could be wrong ?
the relay could be kaput, you need a wiring diagram really to pin point the correct relay. do you have a haynes ?
I had a similar issue following an engine transplant. Pressed the top of the red cut off unit, immediately got fuel pump back.
