Rear Wheel Rubbing.
hazzamondo
Car  986 boxster
Afternoon,
Passenger side rear wheel is rubbing on my phase 1 172. It was fine till a track day at cadwell. Im running standard 15"wheels and toyo 195/50 tyres. Drivers side is fine, no rubbing at all. Checked wheel bearing and have no movement .
Any ideas ???
Spring is fine, im running standard suspension aswell.
Yep its all the time, More noticeable when turning right.
The wheel seems to have developed quite abit of camber aswell, so im thinking more towards rear beam????
Started to rub behind the liner aswell.
and you can make out the camber in this shot.
Right people
i have decided to replace the rear beam , will it have to be a phase one beam or will any mk 2 rs beam fit ???
cheers.
Right after chipping a tooth swapping the stub axle over the wheel still rubs.
Now on the drivers side you can fit your hand behind the wheel, but the passenger side the wheel touches the arch liner.
Any ideas guys before i burn the fucker and take the 1.3 diesel to the ring !!
