Really :S cos been on to tour de force and looked on website and a remap to 195 is £300???? even on k tech racing webiste a remap on there stage 1 is £300 also.
Matt didn't have prices or power claims on his site last time i looked mate?
Firstly welcome
Sadly, there has been a general idea that has come from tuners who massively overestimate power gains for Clios.
Your 182 will have around 175bhp - the exhaut might have got you an exra few bhp, but no where near the usual 10 or so bhp that most list.
Next, check if you have had your cambelt changed - it should be every 5 years, and f it has been done check by who - you need locking tools to get the timing right - even Renault seem to get it wrong half the time - this will loose you bhp (and is half the reason why a lot of 172/182s have low power)
Next thing, a good exhaust, filter and map might net you 180-185bhp. You can have the inlet manifolds enlarged and matched (they come in two pieces) which will get between a few bhp and around 5 or 6bhp depending how bad they are.
Next step is either cams (expensive) or either throttle bodies (circa 2-2.5k) or turbo/supercharger (£££££££££££).
To get a genuine 220-240 bhp you will either need a turbo/supercharger or a very high spec engine with throttle bodies, cams, higher compression pistons - the list goes on.
As Fred has said, either way (Big normally asperated build or turbo/supercharger) will be a good £7000.
Ignore anyone who says you can get 220bhp from things like, exhaust and filter changes or remaps.
Hope that helps
