The Boosh!
ClioSport Admin
								Elise, Duster
				Bojour!
I've had a limp mode issue plague my 182 for a while now, and despite having it plugged into clip it's still stumped many. I think i've worked out whats up with it so just wanted to check the symptoms matched the fault.
Symptoms:
1) Car goes into limp mode
2) Car comes out of limp mode when ignition is turned on and off.
3) Above two stages are repeated sevrel times.
4) Emissions light illuminates
5) Car stops going into limp mode.
6) Emissions light goes off.
7) Start at the top again.
Difference now is that the emissions light never goes off, despite the car having a cat converter fitted. emissions light is constantly on, and I get limp mode mainly when cold. It also idles extremely shite when it's cold.
Could a faulty upper precat lambda sensor cause all of the above?
Any way I can check?
Thanks in advance
Symptoms:
Thanks in advance
