Bmh.01 - total Hero
Car  cliosport 172
Just a proper thankyou to Ben - he has sorted my car - which others had quoted £1000 for the cost of a fuse!
Amazing - he has the gear - and the idea!
A very pleasant young and knowledgable guy.
THANKYOU BEN - THANKYOU SO MUCH!
Fellas - he knows his stuff!
I had a Lupo in the workshop today with exactly the same problem... no start, no diagnostics possible as no power to the port, etc - 5A fuse, job done! Its the normal excuses really:
Kit can't talk to the computer...
... Must be computer that's fucked!
Ben's a good lad and has helped me out with some relay duties before but as he works for Renault he should know them fairly well ;)
Lost of the ecu supplies due to a fuse. No ecu comms with it blown so everyone else was thinking immobisiler issue and new ecu etc. ££££ basically, 90p fuse sorted it.
Was this causing the fuel pump not to prime and only allowing the car to crank?
If so what fuse was it mate?
No as paul says test it first, I didn't just assume it was a fuse. It was tested to be a fuse.
Definately won't assume it's that, would never assume anything with cars let alone french ones....
I have no clue when it comes to auto electrics so don't have a clue where to even start with the tests you have spoke about in here :(
If I called my breakdown lot, would they be able to test for the problems or would they do the bare basics? :-/
