Brake squeal!!! cheap discs and pads or other issue?
Car  clio 182
My brakes squeal like a little piggy!! they were done about a year ago. could this be due to cheap parts being used or could it be down to another issue? any help greatly recieved
Mine squeal a lot, it is usually just brake dust between the pad and disc. Only other time it has done it for me I decided to take mine out and noticed there was some grooves in the pad though in 1 corner, rubbed it down flat again and the squealing went away.
they are drivemaster....... the name doesnt fill you with too much confidence really! I will try the things above and see how i get on. thanks for the advice
i always find that in warm weather mine make noise, but when it cools down its fine again ! also hope the person before you wore them in proper
