wheels spacers cause wheel bearing issues?
Car  MK3 GTI golf 16v
has anyone had any issues with wheel bearings wearing out etc after fitting spacers?
mechanic i was talking to said it can cause them to mess up/wear out fast etc
Theoretically if you push your wheels out further it will put more stress on the bearings.
My previous mini and my current 182 have both had wheels with greater offsets, 8mm and 7mm per side respectively and neither has ever displayed any wheel bearing wear. The extra offset would provide a very similar if not identical effect to adding spacers. Make sure you get hubcentric spacers to avoid balance issues and extended bolts to avoid losing a wheel and thereafter your no claims bonus / life!
if you run like 50mm spacers or something then perhaps, under heavy track use, may shave a few thousand miles off the bearings life. but basically no it wont cause more wear that you'll notice. talking perhaps changing a bearing every 4 years instead of every 5, lol!
No. They alter the steering geometry. Nothing to do with tracking. The steering centre point is shifted away from where it's meant to be.
The big question really is:-
Why?
just wondering, it's not like you're building a replica or anything staringly obvious like that.
so are you saying i need to have anything set up or not ? do you just put the spacers on and thats the end of it, or do i need to take the car somewhere
You can do what you want. I'm simply saying that spacers mess up the steering geometry. It cannot be corrected.
