camberd front wheels
Car  172cup/ insignia
I have found out my car has camber bolts (think thats what their called) fitted how can i put the camber back to normal and were is the best place to get the bolts from. thanks Lee
cheers sorryfor the probably idiotic post.New to messing with camber suspension etc, looks awsome but shreds the inside of the tyre as i found when replacing a front 2 weeks ago
its for track cars mainly, tyre wear isn't an issue on them ;)
get new bolts from the dealer then get the alingment sorted after
Im not sure was done before i bought the car. But you can tell if you look from the front of the car will get a pic up later on
I might be wrong but I thought it was advised to fit camber bolts if you had lowered the car so that it could be adjusted back to a standard setting. I'm possibly completely wrong, I'll be putting eibach sportlines on mine and was under the impression I should fit camber bolts.
i did say mainly ;)
I read it as "manly" :p
But anyway to the OP you don't need to replace them to go back to standard when alignmnet is done they can adjust them.. Like Gaz said though you must be running crazy camber.. Mine is on on -2.5 and even Milton Keynes never ending roundabouts still haven't worn mine unevenly..
