Road cars are sh1t sometimes
Car  182cup & 172 racecar
How can it be that,last weekend we stripped the race car completely,yesterday All the suspension taken off,then when I go to get my washer bottle out of my road car,I get stuck at the first hurdle.Cant get the fcuking wiper arm off:mad::mad::mad::mad:
Just a little rant,thought it would take me 10min to do,1hr later and a cut finger I gave up.
I use a little puller tool for these as they can be very ghey at times. You need to talk to your cars Tony - when they dont help you threaten them with fire... works everytime
Think I might have a wiper pulling tool at home Tony. Can drop it off for you if you still need it as I'm only down the road, if I have it that is.
Oh I did a lot of threatening I can assure you,scared myself.:eek:
Adam that would be great,get searching.Ring me 07850 099009
I just wrap a rag around it, cover it in WD or similar and pull like f**k.
I tried that,hence my very badly cut finger,I nearly smashed the car to bit's.It's just a pain as I've got no way of washing the screen atm.:(
I can't find my wiper pully Tony, I do have this mini vice contraption that I used to use for the job which works perfectly fine. Had mine off for 4 cracked water bottles. used this little thing three of those times.
Can bring it over about 6ish? Don't mind having a bash at it as well, I'm sure you've had enough!
Adam,thats brill.Give me a ring before you leave,cheers.
Cherwell Edge Golf Club.
Yup I cracked the missus windscreen getting hers off her 1.2 when the ice popped a ball joint off the mech inside, cost me £75 :mad:
Done it.
Got the bugger off in the end.
Thanks Adam for your offer,very kind of you.
I now need a pump,mine makes all the right noises,but just dribbles like a junky on LSD,can't be anything else,so one is now on order.
See how I get on tomorrow with that.
Impressed, what obscenity finally make it give in?
Also there is a way of fixing the pump to work, will be a case of trimming down the small bung inside the motor. I did it, it worked. Saves you about £10 which is the price of the motor so if you can go and collect one might be worth saving the extra hassle and/or anymore damages to your extremenities! :)
done the lambda sensor yet you bumbling old fool?
Ah,glad you mentioned that,how the fcuk do you get your hand up there ffs?,but I have done it young Skywalker,but it's not clipped to the subframe.Job for another day with your skinny fingers.
Anyway,new washer motor fitted,works a treat,just a bugger getting the drivers side wiper lined up with the twin little arms,no violence this time,but I think I would rather give birth than work on road cars every day.
(£30)for a poxy motor.
Just to add,why do Renault fit 4 different steering racks to Ph1's?next time your under your car,try and find what one yours is,great fun(not).
I think they had a consultant in from Rover at the time who encouraged using anything they had laying around at the time.
Had a headlight bulb blow on me on the way back from Bedford last night.
Jesus, were these cars only meant to be worked on by ET,I now have cuts all over my hands from light bulb changing,whatever is it going to be next?
Think I might employ a man that can.
You think a Clio is bad? Try a Laguna II OSF bulb... PAS reservoir and pipework is about an inch from the rear of the light unit.
