After doing a bit more research today I decided to order the Goodyear Asymmetric 2's from Camskill.
The RS2's are now going to be stored then fitted to a set of wheels for trackdays next year.
			As long as you take it easy it wet conditions you should be ok with them.
			As long as you drive sensibly you'll be fine Tim, last year in the snow I took the Cup out on R888's with camber and had no problems.
RS2's would have been fine but it's no fun tiptoeing about and having no traction out of slow corners in the wet.
			Winter performance will be horrendous. Tyres like this aren't even supposed to be stored at less than 10 degrees let alone used. The compound will harden and they will degrade considerably. Bad idea.
That was the general consensus I found, it would be a waste to kill them in the winter.
			That is specific to those Toyos listed though. The RS2 is not as soft a compound as in the Toyos so will probably have different temperature limits.
No, Tom is right they're not suitable for use in near freezing conditions.
			Personally I wouldn't go for the goodyears on the megane. Had them on mine when I got it. Tears lasted forever but the fronts wore incredibly quickly on the insides which when I spoke to the local tyre fitter he said was very common
That sounds to me more likely to have been the tracking or the tyre pressures.
			Rainsport 2's ftw had no probs on front last winter. Dunlop sp sport 9000 on the back no bother either. Both great tyres
			A friend runs Sport maxx's on his Meg and they seemed pretty good in the winter last year..
I've never liked the idea of using Uniroyal or Dunlop, just my perception of them as a brand.
			got shut of my rs2's before winter, didn't live up to the hype for me tbh
			TBH I was very impressed with my set of RS2s on fast road -track.
I liked them on road and track as well, really good when warm. They were as good as the PS3's I had before and £50 a corner cheaper.
			IM running rs2s on my meg this winter
I think recommended them to you on MS.net
They are really good as a summer tyre, you'll be fine just go careful when it gets really cold/wet.
If my front left wasn't almost down to 1.6mm I would have kept them on over winter.
