gearbox oil
you got it mate, car on level ground oil to the bottom of the threaded hole(stops dripping out) on front of the box, there is a guide somwhere
It is pretty straight forward tbh, I normally use a funnel with a length of tube on it down to the hole on the front.
On another note, you have to do an involuntary gearbox oil change if you replace the reverse light sensor! That is if you prefer to do things properly rather than refill the gearbox with the same oil you have just drained out!
