Well done Josh+Ktec, 399bhp is a pretty respectable number from a 2871r, how much boost you squeezing through it to hit that? looking at the graph on ktecs blog you can see how much better the spool up is on your lump compared to a low comp (8.5:1) F4R on OE cams. Torque is a lot better as well. Seen's as you have your head ported I can only guess that the milder cams of the F4RT are helping a lot.
If you've got lag or can't make power with that turbo, you've done it WRONG.
Thanks, obviously when I said it was laggy that was in comparison to a GT28RS that I ran. In places below 4500rpm the 28rs was up by 30bhp and 30lb/ft. If you review both my GT2871R dyno run and Ktecs graph of a customers car running a 2871, you'll find there almost a mirror image of one another. I admit I did suffer at the top end of the rev range due to the logg maifold and looking at the figures Josh has pulled you can see that a tubular manifold will flow much better at the top end. As I'm keen to learn new things feel free to post the graphs up of any F4R engines that you've done running a GT2871R so we can compare, plus it'll show both myself and Ktec how it should be done :rasp: The truth is thats just how that turbo performs on an F4R running stock cams........ It would be nice to see how well there Blue clio spools on a tubular with the Tial turbine housing though.
Heres a link to Josh's graph on Ktecs blog
http://www.k-tecracing.com/news.asp (its dated 19th Dec 2011 for anyone looking for it in the future
) further more Ktecs customers car running a GT2871R is on the same link but dated (5th Sep 2011) and for those interested heres my GT2871R graph
If I was doing another 350-400bhp turbo build I'd be using a set off F4RT cams and a new GTX28 60/63R turbo you'd have even better spool than what Josh has whilst still having a compressor wheel that can outflow the turbine wheel.
Well...
I drove a megane with the 2871 fitted to it the weekend after it made 399bhp on the rollers..
Lag you say?
You wouldn't even know it existed, the power delivery was instant, so smooth and awesomely quick.
Quite easily the fastest, smoothest and best car I've ever driven..
Will be looking forward to getting one fitted to my Clio in the new year..
Glad you liked it mate but as above don't expect the same levels of response by simply bolting it to your car, it will be laggier. The only worry I would have (again from personal experience) is gearbox reliability. By all means try an LSD and bracing plate but if it was me I see the Megane R26's as being a much better platform for big power turbo builds.
