Do all Clio 200's have a electric diff?
Car  182 FF
As per title, buying a 200 cup as a track car/daily driver. I was under the impression that they all have them as standard, is this correct?
Right I'll go and ask people with a brain then
No need to spit the dummy mate. Diff isn't electric. If the 200 has a similar EBD/TC system to the 1*2 then braking can adjust stability, but that's about it. To be honest, on track I find it a hinderance and turn it off.
I feel partly respinsible, for bringing aids into the equation.
But, anyway, you've got all forms of stability control and shiz, but not an "eDiff" as such.
eDiffs are bull anyway.
OK,
99% of eDiffs (typically those employed by the mass manufacturers) are bull.
Aparently if you buy a ferrari then it'll handle well?
Such as which car?
I cant think of a single car with an electronic diff (as opposed to just an electronic locking diff) that isnt an improvement over a gay open diff TBH!
The way you are saying 99% of mass manufacturer ones are rubbish makes it sound like they are common, but they still arent common at all.
Are you sure you arent confusing them with something totally different?
The e-diff on the 430 is ok bit out of date these days, the TC system is what makes the car to be honest
Its amazing the rate things move on at.
But the F430 one is a lot more than "ok" though by any standards if you are comparing it to an open diff!
Wow. No idea why people need to be arseholes about it, valid question.
If you don't know the answer, why post?
In a corner, these systems gently brake the inside front wheel to ensure optimal traction these brake-based systems are not technically a differential, they do work well in decreasing under-steer. I wouldn't be surprised if the next gen Renault Sport Clio/Megane got this type of system.
VAG's XDS System is good and so is Alfa's DNA.
You should not get these confused with mechanical limited slip differentials. (well I you knew how they worked you never would I guess)
I think people like volkswagen are partly to blame by calling an element of their traction control setup an "electronic differential" when in fact its nothing to do with the actual differential, they're trying to cash in on peoples positive opinion of setups (which are in the differential itsself) like the ferrari one by giving it the same name.
A bit like the "turbo" vacuum cleaners you might find in currys, lol
I think its down to the "effect" they produce being similar to what a mechanical diff can.
Some of the systems i've tested are actually probably nicer than cars (day to day) fitted with LSD's - If youve ever driven a MK1 FRS in anger you'll know what i mean, makes it uber twichy on certain surfaces. Obviously for track work and LSD is better, but this isnt a bad compromise.
Got it on my old Vr6 - though to be fair it works pretty well - it never holds power when launching, and does regulate the power quite well for what it is - not as good as a decent diff (ie not an open one) but il say it doesn't get itn the way.
What system?
Oh and as Tom has said, VW can get people confused as it is known as EDL - Electronic Diff Lock, which as said it doesn't actually lock the diff
Yeah XDS is the new name for EDL didn't realise it went back that far!
Yeah Iv (Unfortunately) been working for VW for 11 years now - most of my customer's don't realise either lol. TBH I only found originally with my first VR6 years ago by going into it's build details, and noticing under standard equipment it had EDL listed
The FRS feels like that because its a torque biasing diff, it would be less so if it had a plate type diff instead based on my experience of driving cars back to back with both types.
But then obviously it wouldnt be as nicely road mannered as it is with the ATB in it for things like parrellel parking.
No one perfect answer, but the ferrari ediff type system certainly gets pretty close to do everything at once.
I'm not so sure, i've never driven a FWD car with a plate LSD (to my knowledge) so i cant comment.
SAAB's of yesteryear used to allow drivers to run a "faux-LSD" by having the handbrake act on the front wheels.
Same basic principles as modern "eDiff" systems, but a lot simpler to switch off
A plated diff on a road car would be a nightmare,every time you turn the steering wheel it would be clunking away and drive you mad.
Depends how much pressure you have on it, but yes I agree that the ATB type is far more road friendly, I always opt for those on road cars, and even on trackday cars I like ATB diffs too, its only really on loose surfaces that the plate type really has a massive advantage IMHO
RWD cars are not so bad with a plate though, my comments there are only about FWD.
I nearly mentioned the pressure,but thought better of it.If you don't have enough then it becomes a waste of time anyway.
On my Escort rally car I had the diff set up so I could just about turn a circle on full lock without the outside wheel dragging.
But yes you are right,on gravel I would use a plated diff other than that ATB all the way.
That's what we have in the race car.
Do you have a link to a thread about your racecar, have seen it mentioned a couple of times but know nothing about it, sounds interesting :)
