What parts do you get with new Renault front shocks?
Car  Ph2 Clio 172
When buying OEM Renault front shocks, do you get the rubber base for the spring, and the bolt, metal disk and rubber top bit that holds the spring on at the top? Basically, if I buy new front shocks and Sportlines, can I build the new shocks up before hand and then just swap them over with the old ones, or will I need to strip down the old shocks for bits to build up the new ones?
You get the shock and the box it came in! And a new nut as well, maybe, cant remember that bit! But no, you have to either spend a fortune on new bits or just use the old top mounts etc
