Replacing front beaarings - likely to need ABS sensors?
Car  Clio 182 Trophy. No. 189
Car going in to a friends garage on Saturday to have majority of front suspension components replaced but seem to have overlooked a likely problem with the front ABS sensors.
Are these likely to be damaged if the hubs are removed for new bearings to be pressed in?
Thanks in advance!
Arent they just screwed in with 2 screws. So should be detached before going to town on the bearing
I did think that but reading some posts on here says they are near on impossible to remove without damaging them!
They won't come out - ever. I managed to move mine enough so the bearing could be replaced with no problem. Just moving one took a few hours and much swearing. I'm not even sure if its a problem fitting a bearing with them in place anyway.
As above, They are almost impossible to get out in one piece.
Should be able to disconnect the cable however and leave it attached to the hub.
Thanks both - just spoke to friend at garage who was adamant this will not be a problem!
