o/s Main beam and Xenon not working.
Car  RB 182
Evening Gents!
First post here but I'll introduce myself in another thread somwhere!
Right I have just bought the 04 182 from a Renault dealer. Before I go and give my car up for someone to have a look at this weekend I was just thinking if there was a simple explanation for this or if this was a common fault? The lights were working fine yesterday but for both of them to go off?
Symptoms are:
*Auto Lights not working
*o/s xenon not working
*o/s full beam not working
*When switching on full beam the left indicator stays solid on
Sounds like a dodgy connection to me or the unit itself?
If anyone could shed some lights (pun not intended) on this I would be very grateful :)
Best regards,
-Dave
If i were you i would check if all the connections were ok eg not damaged due to water in them also someone correct me if i am wrong but the indicator issue sounds like a ground problem
** Update **
Searched for Autolights problem -
Tried the click-the-sidelights-twice-untill-you-hear-a-beep technique just then and worked a treat!
Xenon and Full beam still not working though. The Xenon flashes then just turns itself off, am i right in thinking this could be the ballast that needs replacing?!
Thanks for the reply!
I have checked the connections and they all seem alright. Ill have a proper look at them tomorrow afternoon to see if i can spy anything that looks out of place.
In regards to the Indicator; my friend told me he had a BMW which did this when there was a headlight out as a safety feature.. Could it be the same principal?
