Oil drain plug rounded HELP
Car  clio 1.4 16v 02
Just got all prepared to service the clio and the effin sump plug is rounded, seriously rounded! how the hell do I get it out? mole grips wont work and I dont have vice grips :(
Drill it out like a boss.
*DISCLAIMER*
I take no responsibility for any 'mishaps' that may occur...
Try a kit from trend, about 15 quid one side drills a hole the other is a screw type thing but with reverse thread do when it bites, it will turn your plug too
Don't drill or weld it!
Should easily come off with some mole grips, I've done it before
had a go at smacking it round with a hammer and chisel and a hammer and flat head.. just takes chunks out of it, hence why I asked if the bung is steel or alloy :(
you know its a square hole ur not thinking its like a normal bolt you use a spanner on are you?
I'm well aware of that, but to have a hole you need a surround, hence the lovely round surround around the square hole that you put your mole grips on
